Zywll 310 VPN L2TP Connection - Can't see computers on network
bpworker
bpworker Posts: 2 image  Freshman Member
edited April 2021 in Security
When I connect to my VPN (Zywall 310) everything connects fine, I can ping local computers and devices on the network and I can access devices like a copier via it's web interface. However when I look at the network I don't see any of the remote local devices. I'm assuming because I can access them via IP the connection is fine but perhaps some sort of DNS setting or setup needs to be done so I can just see them under Network.
    For the VPN connection in advance is Enable NetBIOS broadcast over IPSec checked?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @bpworker
    If establishing L2TP VPN connection successfully you can navigate Web GUI path to check L2TP user connection status: MONITOR > VPN Monitor > L2TP over IPsec > L2TP_Remote_Users just like the following picture shows.
