G5 Config Backup / Restore options
waldosmiles
in Home Router
I had to reset and redo the config on my Armor G5 this morning. I was having trouble passing data. Durning the reset and setting up the G5 again, there was a message that stated the config is backed up to the Zyxel Cloud. Is this correct? Where is it? How do I restore it? Can I manually issue a save or is it done automatically? Do I have to be logged in through the Zyxel for this feature to work or will being logged in locally work also?
Dear @waldosmiles
We do not have a backup option for the configuration on the web gui .
We’ll evaluate the feature.
Thanks for your suggestion.
Best regards,
Jerry
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 482 News and Release
