VMG8828-B50B static DHCP limit
carlo_mava
I'm trying to configure on my router a static (local) IP for my devices.
When I try to configure more than 10 devices I get an error message.
My router is the VMG8828-B50B, in the WINDTRE HUB version.
The firmware version is V7.0.1_WD3.1T7d2.
Hello/Ciao @carlo_mava
I think that there is a limit.
According to the release notes of a similar router VMG8823-B50B, there is a limit.
- there was a bug that limited it at 8, and then it was updated to have a limit of 32 static IP address allocations, and this was changed in 2018, see the release notes in ftp://ftp.zyxel.com/VMG8823-B50B/firmware/ for ABEJ.4 and ABEJ.5
As WIND has customised firmware, then you might want to contact WIND directly about why it stops in the customised version at 10.
I hope that this is helpful.
Kind regards,
Tony0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
