USG20W: disable the Admin Web authentification on the WAN side, but keep it internally (LAN)
Hi all, this question has been asked before but my requirements are slightly different/simpler.
I have the Zyxel USG20W. I have added the rules as per the manual to prevent anyone logging in to the admin page from the WAN but what I really want is to have the Web Administration page not appear at all for anyone coming in from the WAN ( but be visible , obviously, from the LAN) . Is there a config setting I am missing?
Thanks in advance
Moonmoth
Thanks in advance
Moonmoth
Hi @moonmoth,
It control by Security policy “Wan to ZyWall”, you can remove Web GUI https port from Default_Allow_Wan_to_Zywall service group.
Go to “Configuration > Object > Service > Service group”, click Default_Allow_Wan_to_Zywall and remove https port.
Thats fixed it. Thanks very much. You are a star.
Moonmoth0
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
