Big speed hit with bandwidth management enabled on VPN2S
PeterUK
PeterUK Posts: 4,148 image  Guru Member
edited April 2021 in Security
With VPN2S V1.20(ABLN.2) 00201030C1
Setup test on the VPN2S
WAN set to 192.168.255.55/255.255.255.0
PC1 connected to WAN on VPN2S IP 192.168.255.53/255.255.255.0
LAN2 192.168.2.1/255.255.255.0
PC2 connected to LAN2 on VPN2S with IP 192.168.2.2/255.255.255.0 gateway 192.168.2.1
Doing a transfer test with MS file share without bandwidth management enabled is 950Mb
Doing a transfer test with MS file share with bandwidth management enabled just set to 1048576 gets 50Mb
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,350 image  Guru Member
    Hi @PeterUK
    We can reproduce it and will do further investigation for this symptom.
  • mMontana
    mMontana Posts: 1,441 image  Guru Member
    Side question for VPN2S and bwm: is possible to set a lower than 1024kbs for upstream?
  • Zyxel_Jeff
    VPN2S supports 1000 kbps minimum bandwidth management.
  • mMontana
    Well thanks, i already read that. And IMVHO there are connections which the actual upload rate is... lower. Therefore, less than 1000 kbps should be a value that could be inserted...
