NWA1123-ACV2 and AppleDevices
Alessandro_DeLeo1
Alessandro_DeLeo1 Posts: 1 image  Freshman Member
edited April 2021 in Nebula
The AC does’t work good with iphones and ipads. Absolutelly low connection and Continous network lack. Any ideas to solve this big problem ?
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @Alessandro_DeLeo1
    Low connection and continuous network lack might be caused by the WiFi overage is not good enough, too much interference in the wifi environment, or related with the deployment. We can adjust the configuration to steer the sation connect to the correct AP. Can you provide me your org/site name and enable zyxel support(Help > Support request) for me? I will help to check the configurations and update to you.
    Joslyn
Nebula Tips & Tricks
