Zyxel VMG1312-B10D: Your device is under attack.
Luca_Nardini
Luca_Nardini Posts: 5  Freshman Member
edited March 2019 in Smart Home Product
Buongiorno.
Quali sono le cause che generano questo messaggio automatico (Your device is under attack) nel router Zyxel VMG1312-B10D?
E' frustrante non avere alcun tipo di spiegazione di questo problema.
Grazie.
Luca Nardini.
#CPE_Mar_2019
  • Zyxel_Support_CPE
    Zyxel_Support_CPE Posts: 188  Zyxel Employee
    Sixth Anniversary
    Hi Luca_Nardini,
    Can you please let me know which situation you found this alarm message? And provide screenshot to me, thanks.
  • Luca_Nardini
    edited February 2021
    This is the only information.
    How can block the IP's source?
  • tonygibbs16
    tonygibbs16 Posts: 971  Guru Member
    Hello @Zyxel_Support_CPE and @Luca_Nardini,
    I get similar messages recorded in Syslog messages from my VMG1312_B10D running V5.13(AAXA.10)C0 .
    Am I correct in thinking that this means that firewall is blocking the attacks, as I have it set on Medium?
    Kind regards,
         Tony
    SourceMessageHostnameTimestamp (Device)SeverityTagFacilityApp NameProc IdMsg IdData
      0 to 50
    04/02/2021 23:36:26192.168.1.1Feb 4 23:36:30 kern.alert kernel: IN=ppp2.3 OUT= MAC= SRC=103.145.13.60 DST=51.155.x.173 LEN=428 TOS=0x00 PREC=0x00 TTL=48 ID=53920 DF PROTO=UDP SPT=5209 DPT=5168 LEN=408 MARK=0x1000000000-00 00:00:0000
    04/02/2021 23:36:25192.168.1.1Feb 4 23:36:30 kern.alert kernel: IN=ppp2.3 OUT= MAC= SRC=103.145.13.60 DST=51.155.x.173 LEN=428 TOS=0x00 PREC=0x00 TTL=48 ID=53866 DF PROTO=UDP SPT=5209 DPT=5068 LEN=408 MARK=0x10000000
  • Luca_Nardini
    Hello tonygibbs16.
    Exactly!
    With your help I've find the correct menù.
    Thanks.
  • tonygibbs16
    Hello @Luca_Nardini
    You are welcome.
    Kind regards, Tony
  • Ciao @Luca_Nardini
    Io ho lo stesso problema che ricevo quelle mail ogni 10 minuti circa.
    Come hai risolto???
    Grazie
  • Luca_Nardini
    Nessuna soluzione applicabile lato router.
    Abbiamo sfruttato il FailToBan del ns. firewall che blocca gli IP con troppi tentativi di accesso falliti. Dopo un po' gli attacchi si limitano sino a scomparire.
    Come hai risolto???
    Grazie
