VPN on ZYXEL XMG3927-B50A
bigkenny
I have a XMG3927-B50A Modem/Router only bought in Nov` 2020 can I install/run a VPN off itVP
Hello @bigkenny
Looking at the user manual availble at https://spdl.zyxel.com/XMG3927-B50A/user_guide/XMG3927-B50A_V5.13_5.50.pdf shows under the Application Layer Gateway (ALG) that you can run an IPSEC VPN through it or a PPTP VPN through it.
But the XMG3927-B50A cannot be the endpoint of the VPN as a VPN server or VPN client.
I hope that this is helpful.
Kind regards, Tony0 -
bigkenny said:Hi,I have a XMG3927-B50A Modem/Router only bought in Nov` 2020 can I install/run a VPN off itVPtonygibbs16 said:Hello @bigkenny
Kind regards, Tony
Hi Tony many thanks for this info I had a quick skim through the manual but missed this and with me not seeing it as listed stood out as VPN I was not to sure. I will now look into it more many thanks for your help
- 3K Nebula
- 222 Nebula Ideas
- 620 USG FLEX H Series
- 350 Security Ideas
- 53 Wireless Ideas
- 488 News and Release
- 108 Security Highlight
