What is the difference between PVID , untagged and tagged
businessuer
Firstly, how do I set a native vlan for a port in nebula switch?
Secondly, I understand that untagged means access in cisco, so why we can have multiple untagged vlan in 1 port?
Thirdly, what is PVID? Is it access vlan?
Fourthly, what is the difference between PVID and configuring as untagged vlan?
Hi @businessuer,
Welcome to Zyxel community!
I will answer your question one by one as following:
1. How do I set a native vlan for a port in nebula switch?
Kindly inform you that native vlan is PVID on Nebula switch.
Once you login to NCC web portal, go to Switch > Configure > Switch ports, and then click one port that you would like to set native vlan.
I use port 1 as an example here, as you can see there is a PVID where you can put different vlan on it instead of default PVID 1.
2. I understand that untagged means access in Cisco, so why we can have multiple untagged vlan in 1 port?
We cannot configure multiple untagged vlan on the same port of Nebula switch.
3. What is PVID? Is it access vlan?
The description of PVID as below
As I described above, PVID is native VLAN for Nebula switch.
Trunk and Access VLAN is a VLAN type like you know on Cisco Switch.
4. What is the difference between PVID and configuring as untagged vlan?
PVID, as I described on question 1
Untagged vlan, as I described on question 3
SincerelyAdam
Hi @businessuer,
SincerelyAdam
I still dont understand the difference between PVID and untagged vlan.
What happens if I put PVID 2 and untagged vlan as 2 both at the same time?
Or is it better to put PVID as 1 (default) and untagged vlan as 2 at the same time?
Assume that vlan 2 is connected to a computer.0 -
Hi @businessuer ,
Well, for your question "What happens if I put PVID 2 and untagged vlan as 2 both at the same time?"- When you put VLAN 2 as untagged and PVID 2 on a specific port, the port forwards the packets of connected PC to VLAN 2 without tagging.
- When you put VLAN 2 as untagged and PVID 1(default) on a specific port, the connected PC can reach VLAN 1 only.
You may think PVID in this way,- PVID is native VLAN.
- PVID is access VLAN when you configure switchport on Cisco switch.
Don't be hesitate to inquire us if there is anything unclear.Adam
I dont understand scenario 2.
If native vlan is 1 and access vlan is 2,
How will the uplink process the frame?
Diagram will be better0 -
Hi @businessuer ,
Sorry for the wrong information of scenario 2,
My apology to make this confusion.
If there is anything still unclear, I will draw a diagram to help you for further understanding.
Adam
Hi Nebula_Adam,
A diagram would be best. If you are free you can help me do it.0 -
Hi @businessuer
currently Adam is busy for a while. Are you fine, we provide diagram around 2/19, if you need it earlier, may I take your E-Mail and another Agent will re-check your requirement earlier?
Let me know.
Kind Regards,
Tobias0 -
19/2 will be ok0
Hi @businessuer ,
Let me explain more explicit.
Compare VLAN between Zyxel and Cisco:
When configuring VLAN on Zyxel switch (Standalone mode), you need to:
1. Create VLAN
2. Specify tagged or untagged port
3. Configure PVID on a specific port (this action is the same as configuring access port for Cisco switch)
When configuring VLAN on Cisco switch, you need to:
1. Create VLAN
2. Configure access or trunk VLAN on a specific port (this action is similar to step 2 and 3 of Zyxel switch)
When configuring VLAN on Zyxel Nebula switch (Cloud mode), you need to:
1. Choose specific port(s)
2. Select access or trunk type (This action is the same as configuring Cisco switch)
2-1. If use access (untagged), enter PVID (like native VLAN in Cisco Switch)
2-2. If use trunk (tagged), configure allowed VLANs you want (The default is allowed all) and PVID.
Scenario 1 : VLAN 2 (untagged port 1), PVID 1
Scenario 2 : VLAN 2 (untagged port 2), PVID 2
Hope it hopes and every clear =DAdam
When I configure zyxel switch in standalone mode:
1. Create VLAN
Will step 1 and step 3 overlap with each other?
Let say :
in step 1 create vlan 2.
in step 2 make vlan 2 untagged but the original vlan 1 is also untagged.
in step 3 make this port a PVID of vlan 3.
Now what will happen? This is the confusion.
Will it be switchport access vlan 1 or 2 or 3 ?
- 435 Beta Program
- 175 Nebula Ideas
- 422 USG FLEX H Series
- 297 Security Ideas
- 272 Service & License
- 418 News and Release
- 89 Security Highlight
