pb with Secuextender on 20H2
Bruno_comc
Bruno_comc Posts: 1 image  Freshman Member
edited April 2021 in Security
Hi
Before the upgrade to 20H2, we had no connection problem. Once we have made the update, when we launch the connection, it's end after 20 seconds. We use Secuextender 4.0.3.0. It's ok for TAP-Windows Adapter V9 for Zyxel SecuExtender in device manager and visual c++2015 is installed. I repeat it worked before the update to 20H2.
Thank you for your reply
