Understanding WAP Aerials
Camperdownfamily
I have a WLAN managed by a NXC2500. I have good coverage in the main building and over external areas, but we have a temporary new building and although the signal is strong outside the building, it is poor to non-existent inside. With the building being temporary, I am looking to use Zymesh to cover it rather than installing cables.
Up to now, all WAPs have been NWA-5121s so I am not up to speed on external aerials on WAPs.
As an example, I have been looking at an NWA-5560N to cover the temporary building and to connect it into the network through Zymesh, but to get a strong signal to it, ideally I need one or more of it's aerials to be outside the temporary building. The unit has four removable aerials, so can I replace one or two of them with external ones like the EXT108 for example? If so, how many of the four should be replaced? Which of them should be replaced?
As you can see ,I am a complete newbie when it comes to the practicalities of this. Can anyone give me a bit of a "for Dummies" insight of what I need to make this work?
Thanks in advance.
Thanks in advance.
Hi @Camperdownfamily
Welcome to the Community Forum.
So far the NWA5560N is Phase Out already, so not much info anymore available.
In the end you need mimum replace 2 antenna (5Ghz module) the other 2 are for 2,4Ghz module but for MESH it´s fine to go from 5 to 5 Ghz site.
I only have it more detailed currently for WAC Series, you can refer to here:
https://support.zyxel.eu/hc/en-us/articles/360003285500-Connecting-antennas-to-the-WAC6553D-E
For antenna make sure the type is correct, you can use the connector information in above article.
Kind Regards,
Tobias0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
