annoying connection interruptions - reason 8
Hi @Wookie
The reason code 8 means the AP received the disassociation from the client. Since the roaming is triggered by the client when it reaches its roaming threshold. The signal shows -7x which is determined not good in the logs you provided, it might the client eager to find the AP to associate with better signal.
Could you the distance between APs in the first floor and if there are any obstacles? We could understand the annoying of interruptions and would like to help. Thank you.
Regards,
Bella
Hi @Wookie
Regards,
Bella
Hi BellaThanks for your quick reply. I did some research and it seems that mac OS roams when the signal is below -70. Initially I thought the problem would come from the NWAs, but it doesnt seem so. I configured mac OS to choose the strongest Wifi-signal and as for now it seems to help. If I run into future problem I would be happy to come back to you.Regards0
Hi Wookie,
you are always welcome, thanks for sharing!
Kind Regards,
Tobias0
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
