USG Series Converter - converting configuration from USG210 to ATP500
I would like to convert configuration from USG210 to the new ATP500 we got.
looking at the https://convert.cloud.zyxel.com/ there is no option to select ATP500 as output:
What can I do?
any other suggestion, or particular problematic steps I should consider?
Thank you
Best Regards
What can I do?
Thank you
Best Regards
Hi @phphil
Thanks for coming back to us.
You can try to choose ATP200 and convert it first, then remove the "header" of the .conf file (with Firmware and model info) and try apply this config into ATP500.
If that works, all fine, if not you can check "File Manager" category in log afterwards to look for "Errors" and correct it.
If everthing failed, feel free to open a ticket to our Support Team with USG210 config and we will help you to get a config you can use.
https://support.zyxel.eu/hc/en-us/requests/new?ticket_form_id=114093996354
Kind Regards,
Tobias0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
