[NEBULA] IPSec VPN established by NCP-Client
https://businessforum.zyxel.com/discussion/209/how-to-establish-site-to-site-ipsec-vpn-between-nebula-and-non-nebula-devices#latest
Check this one in the FAQ. Although it's not using a NCP device as example, I think the idea is similar. You need to have exactly the same Phase 1 and Phase 2 settings in both devices, NCP and Nebula.
"You will never walk along"0 -
Well, is there something how to configure the connection in the zywall ipsec client? I figured out, that it is nearly similar.
And then I was also looking for a way to configure the tunnel on an ios device...0 -
You can refer this discussion
- 588 USG FLEX H Series
- 477 News and Release
