upgrade usg40
antonellobellisario
in my usg40 I have in "firmware status":
1) running V4.39 (AALA.0)
2) standby V4.62 (AALA.0)
how can i start the updated firmware (4.62) without losing the configuration? 0
First save your config.
Upload V4.62 to slot 2 again then say yes to reboot and your config will update with the new firmware.
If you don’t want to lose V4.39 configuration which you are running now.
You may refer to the below methods:
Method1.
STEP1. Download V4.39 startup-config file for backup purpose.
STEP2. Switch to standby partition and reboot device.
STEP3. Upload startup-config and apply it.
Method 2.
STEP2. Update V4.62 firmware to this running partition.
Thanks.0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
