Traffic Statistics error
2»
  • Skylink
    Skylink Posts: 32  Freshman Member
    First Anniversary 10 Comments Friend Collector
    the command is Router(config)# clear report
    No effect.
    The error is still there.
    Why is "guest" the status of that (dftunnel1-30) interface? And why the packets rising like "vlan30"? There should be a relationship between this 2 interfaces?
    I saw is available firmware 4.31 but no mentions about this issue.
    Should i try to install it? or make a reset of USG?
  • Skylink
    Thank you Zyxel_Cooldia!
    Deleting Chrome cookies of Zyxel private ip the "traffic statistics" works again!
  • jianyun63
    I got exactly the same problem after I uograded from USG100 to USG200.
    I tried the above, it works!Thanks!
Security Highlight
