Traffic Statistics error
No effect.Zyxel_Cooldia said:the command is Router(config)# clear report
The error is still there.
Why is "guest" the status of that (dftunnel1-30) interface? And why the packets rising like "vlan30"? There should be a relationship between this 2 interfaces?
I saw is available firmware 4.31 but no mentions about this issue.
Should i try to install it? or make a reset of USG?0 -
Thank you Zyxel_Cooldia!
Deleting Chrome cookies of Zyxel private ip the "traffic statistics" works again!
I got exactly the same problem after I uograded from USG100 to USG200.
I tried the above, it works!Thanks!
- 588 USG FLEX H Series
- 477 News and Release
