Zyxel P-660HN - Access and setting up a LAN
Hello @discover
I am glad that you have had some success.
The DHCP server for the local area networking (LAN) is set-up under Network Settings then Home Networking then LAN Setup.
The following user guide extracts might help you:
and
If you set DHCP Server State to Enable then you can set the range of IP addresses that are given out but the P-660HN will not always give the same IP address to the same device.
But under Network Settings then Home Network then Static DHCP you can add settings so that some IP address is given to the same device based on its MAC address, see below:
I have taken these instructions from the user guide for P-660HN-51 at ftp://ftp.zyxel.com/P-660HN-51/user_guide/P-660HN-51_1.10P-660HN-51.pdf .
There are many models of P-660HN so I hope that I have guessed a relevant one.
I hope that this is helpful.
Kind regards,
Tony
- 237 Nebula Ideas
- 6.8K Security
- 744 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
