upgrade usg40
antonellobellisario
antonellobellisario Posts: 17  Freshman Member
edited April 2021 in Security
in my usg40 I have in "firmware status":
1) running V4.39 (AALA.0)
2) standby V4.62 (AALA.0)
how can i start the updated firmware (4.62) without losing the configuration?
    PeterUK Posts: 3,645  Guru Member
    edited February 2021
    First save your config.
    Upload V4.62 to slot 2 again then say yes to reboot and your config will update with the new firmware.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,311  Zyxel Employee
    Hi @antonellobellisario
    If you don’t want to lose V4.39 configuration which you are running now.
    You may refer to the below methods:
    Method1.
    STEP1. Download V4.39 startup-config file for backup purpose.
    STEP2. Switch to standby partition and reboot device.
    STEP3. Upload startup-config and apply it.
    Method 2.
    STEP2. Update V4.62 firmware to this running partition.
    Thanks.
