USG110 Inactive WAN not marked as inactive
Martin_Kuchar
latest firmware, 2 wan ports, auto fallback, connectivity check..
Today, we have problem on wan1 (ISP down, no internet). USG auto closed wan1 and opened wan2. Internet is OK, no problem with network. BUT although in System Log/Connectivity Check is clearly stated "The wan1 routing status is set to DEAD by connectivity-check" and "The link status of wan1 interface is inactive.", on Dasboard the wan1 is marked as OK and the same in Monitor->System Status->Interface Status - "1000M/Full" instead of something like "Inactive"
Any ideas?
Thank you for your suggestion.
Currently, we don’t support this feature.
We will put it into our future development evaluation.
Thanks.
Maybe the ethernet connection to next hop, e.g. Proxy Server etc. still works ... and the fail is only behind the next station.
USG_User said:Maybe the ethernet connection to next hop, e.g. Proxy Server etc. still works ... and the fail is only behind the next station.
Yes, this is the case. Fiber GW between USG and Internet is online. But when connectivity check inactivated the interface, admin should know about this. Log is not sufficient. When inteface is disabled by Connectivity check, it should be clearly marked as Inactive at least on the Dashboard graphics!
Thanks.
Hi all, please add this feature ... Information about inactive interface is most important ! (port is OK, but internet from provider is KO) ...
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
