Jason
NSG100 Dual Active WAN, separate LAN clients
Quinton_Büchler
Good day All,
I am almost 99% sure this is an active config.
I have dedicated WAN1 link, with a LTE on WAN2.
I need to allow LAN clients 1-10 to use WAN 1 then LAN clients 11-20 to utilize WAN 2.
WAN load balancing algorithm is currently set to Lead load first.
I have configured Port 3-4 on LAN1 and Port 5-6 for LAN2.
Now I need to have LAN1 utilize WAN1 and LAN2 utilize WAN2.
How would I go about this?
Reason for this setup:
WAN1: Data intensive users
WAN2: Less data intensive users
Hi @Quinton_Büchler ,
Welcome to Zyxel Community!
If you would like to assign LAN1 clients going through WAN1 and LAN2 clients going through WAN2, you may create two policy route rules for it.
The configuration location is at "Security gateway > Configure > Policy route".
Please refer to the link below for the guideline:
https://community.zyxel.com/en/discussion/1488/how-to-configure-policy-route-on-nsg
Hope it helps.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
