IPSec error
[Deleted User]
[Deleted User] Posts: 21 image  Freshman Member
edited April 2021 in Security
Hi
By use IPSec connection to VPN100 I get the following error:
Error - IPSec - Packet(UDP) cannot be sent. reason: System dropped
How can I work out the issues behind?
Connected to the VPN100 is a Windows-Notebook with Windows on board VPN
Thank You for Your help, Dani
  • Zyxel_Vic
    Zyxel_Vic Posts: 323 image  Zyxel Employee
    25 Answers First Comment Friend Collector Eighth Anniversary
    Hi @Dany
    Are you configuring IPSec or L2TP VPN? To windows native VPN utility, what you should set is L2TP over IPSec. For more information, you can refer to this FAQ link.
  • [Deleted User]
    Hi @Zyxel_Vic
    Yes exactly. All configuration work is done as in the FAQ described.
  • Zyxel_Vic
    Hi @Dany
    Can you share the config file with us in private message? We can help to check on your settings.
