What is the difference between PVID , untagged and tagged
Hi @businessuer
Thanks for reply.
To answer your question:- Step 1 and 3 will not overlap since step 3 is like assigning a port to a VLAN via the PVID you configured.
- According to the scenario you provided, the port with PVID 3 ends up to VLAN 3. Since your scenario has no VLAN 3, so there is no any VLAN 3 traffic even you put PVID 3.
Hope it helps.Adam
Ok but what if I also create vlan 2 and 3 in the vlan database?Let say :in step 1 create vlan 2 as well as vlan 3 in vlan database.in step 2 make vlan 2 untagged but the original vlan 1 is also untagged.in step 3 make this port a PVID of vlan 3.Now what will happen?What I mean is will step 2 and 3 overlap?
Does PVID 3 or untagged 2 takes precedence?
Why is vlan 1 untagged still there even though I create 2 and 3 ?0 -
@businessuer
The scenario will not take any effect still since you did not configure VLAN 3 to untagged a port.
Let me put in this way, refer to your scenario:
#I use port 10 as an example
VLAN 1, untagged port 10 | port 10 PVID = 1
↓ step.1 (Create VLAN)
VLAN1, untagged port 10 | port 10 PVID = 1
VLAN2, |
VLAN3, |
↓ step.2 (VLAN 2, untagged port 10)
VLAN2, untagged port 10 |
VLAN3, tagged port 10 |
↓ step.3 (Configure PVID 3 to port 10)
VLAN1, untagged port 10 | port 10 PVID = 3
When port 10 receives packets, the behavior will be:
untagged packets → assign to VLAN 3
tagged packets → assign to VLAN 1 and 2
When port 10 sends packets out, the behavior will be:
VLAN 3 → tagged packet out
VLAN 1 and 2 → untagged packet out
For your question:
Step 2 and 3 will not overlap.
PVID takes higher priorityAdam
Dont understand this.
Send is egress and receive is ingress?0 -
Adam
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
