XGS4600-32F Data abort occured
maxsaf
maxsaf Posts: 11 image  Freshman Member
edited August 2022 in Switch
I lost inbound and outbound management access to switch during OSPF configuration process.  Now SYS led blinking continuously. Getting log using RS-232
Data abort occured
Fault Status = 0x00000008
Fault Addr = 0xE59FF570
Current Task TCB = 0x6371AB28
Current Task Name = PINI
Current Task Stack Start = 0x6371ABE0
Current Task Stack End = 0x6372ABDE
Is there a proper way to recover switch back to working condition?
  • DogLoveSwitch
    DogLoveSwitch Posts: 7 image  Freshman Member
    It seems there is a problem on switch.
    What was the last action you did before finding these message?
  • maxsaf
    I did change OSPF area ID and click Apply
  • Zyxel_Ryan
    Zyxel_Ryan Posts: 72 image  Zyxel Employee
    First Answer First Comment Friend Collector
    Hi @maxsaf
    It looks that there is some error happening on your switch.
    Could you PM me your configuration directly and let us to find some clues?
    Ryan
  • maxsaf
    I could but i don`t have backup config. Is there any way to get current config in that condition? I don't have management access, Rs232 only. Switch continuously rebooting.
  • Zyxel_Ryan
    Hi @maxsaf
    I will PM you for some detailed information about how to recover your switch.
    Ryan
  • Zyxel_Ryan
    Hi @maxsaf
    As the discussion, due to you have recovered device before we collect enough information, we are not able to find the root cause in time. If it happens next time, we will try to find the problem out.
    Ryan
