IDP WHATAPP
juan_moreno
Hi everyone,
im facing problem with my IDP on my Zywall 310
It´s block Whatsapp sending and recieving files.
How can i solve within disabling the IDP
BEST REGARDS
BEST REGARDS
Hi @juan_moreno,
When you are sending and receiving files by WhatsApp, do you see any IDP blocking log on “Monitor > Log > Category=IDP” ?
Hi Cooldia,
nop, that was the first i checked.0 -
Hi @juan_moreno,
Can you send me your configuration file via private message. I will try it on local lab.
BTW, I will move this post to “ZyWall VPN series”, “Security Services” is mainly for myZyxel license related topic.
Hi @juan_moreno
i've WhatsApp successfull running trough a USG with IDP
What i've done
1. stay sure, the following Patterns are not active in your IDP Profile
2. I've the following 3 additional ports configured on the USG to get fully connected with WhatsApp
Port 5222-5223/tcp
Port 3478/udp
With this configuration, WhatsApp can be used from the LAN to the WAN (with active IDP).
Regards & good luck
Christian
- 588 USG FLEX H Series
- 476 News and Release
