Secuextender connecion is not stable
Fabio
Fabio Posts: 31 image  Freshman Member
First Comment Sixth Anniversary
edited April 2021 in Security
I see those  lines on logs.
 2021/03/02 13:37:46 ][SecuExtender Agent][DEBUG]   TAP-Windows Driver Version 9.9
[ 2021/03/02 13:37:46 ][SecuExtender Agent][DEBUG]   TAP-Windows MTU = 1370
[ 2021/03/02 13:37:46 ][SecuExtender Agent][INFO]    security tunnel is created!
[ 2021/03/02 13:37:47 ][SecuExtender Agent][DEBUG]   Entering main loop
[ 2021/03/02 13:37:47 ][SecuExtender Agent][INFO]    GetOverlappedResult success, agentState.aState = 2,  agentState.aError = 0, dwReadBytes = 8
[ 2021/03/02 13:37:48 ][SecuExtender Agent][INFO]    GetOverlappedResult success, agentState.aState = 3,  agentState.aError = 0, dwReadBytes = 8
[ 2021/03/02 13:38:04 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:38:05 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:38:06 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:38:07 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:12 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:13 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:14 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:15 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:16 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:17 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:18 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:19 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:20 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:21 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:22 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:23 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:41 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:42 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:43 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:44 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:45 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:46 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:39:47 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:40:51 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:40:52 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:40:53 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:40:54 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:42:00 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:43:05 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:43:06 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:44:10 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:44:11 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:44:12 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:44:13 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:44:14 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:44:15 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:44:16 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:44:17 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:44:18 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:44:19 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:45:23 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:45:24 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:46:29 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:46:30 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
[ 2021/03/02 13:46:31 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
  • Asgatlat
    Asgatlat Posts: 130 image  Ally Member
    First Comment Friend Collector Eighth Anniversary
    hi @Fabio
    which version do you have ?
    the 4.0.4.0 fixes :
    [BUGFIX] Fix redundant routing rule when disconnect SSLVPN (eits#191000855)
  • Fabio
    I have 4.0.3.0  I will try to update
  • Fabio
    I update to 4.0.4.0 but error is still there
    Certificate Authority - G2
    [ 2021/03/05 04:22:41 ][SecuExtender Agent][DETAIL]  SSL session is created
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DEBUG]   SSL Connection is going to be closed
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][INFO]    user login device success
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][INFO]    Creating secure tunnel to External.etere.com:443
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][INFO]    Connect to 1113640099:443
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][INFO]    Local address is 3232235785
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DEBUG]   Connect success.
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DETAIL]  Handshake LoopCounter: 0
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DETAIL]  2086 bytes of handshake data received
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DETAIL]  InitializeSecurityContext returns 0x90312
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DETAIL]  Send 126 bytes of handshake data
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DETAIL]  Handshake LoopCounter: 1
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DETAIL]  274 bytes of handshake data received
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DETAIL]  InitializeSecurityContext returns 0x0
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DETAIL]  SSL Handshake is successful
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DETAIL]  STREAM_SIZE: Header: 13 Trailer: 16, MaxMessage: 16384
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DETAIL]  Secure session is created
    [ 2021/03/05 04:22:43 ][SecuExtender Agent][DETAIL]  Secure session negotiation begin
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DETAIL]  stage 1...done
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DETAIL]  stage 2...done
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DETAIL]  stage 3...done
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DETAIL]  stage 4...done
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DETAIL]  Secure session negotiation end
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DETAIL]  Bring up virtual interface...
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   XML configuration is: <configuration><node><ip>192.168.200.10</ip><mask>255.255.255.255</mask><localip>192.168.200.1</localip></node><dns>172.31.100.8</dns><dns>172.31.100.7</dns><wins>0.0.0.0</wins><wins>0.0.0.0</wins><area><ip>0.0.0.0</ip><mask>0.0.0.0</mask></area></configuration>
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   nodeip 192.168.200.10
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   netmask 255.255.255.255
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   localip 192.168.200.1
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   wins0 0.0.0.0
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   wins1 0.0.0.0
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   dns1 172.31.100.8
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   dns2 172.31.100.7
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   area 0 ip 0.0.0.0
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   areamask 0.0.0.0
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DETAIL]  Successfully retrieve network configuration.
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][INFO]    ConfigSet.nodeip = 192.168.200.10
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][INFO]    ConfigSet.localip = 192.168.200.1
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][INFO]    ConfigSet.netmask = 255.255.255.255
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   Virtual network interface: \\.\Global\{CED1F658-E97A-4EFA-923C-7831997EDFDE}.tap
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   TAP-Windows Driver Version 9.9
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   TAP-Windows MTU = 1370
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][INFO]    security tunnel is created!
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][DEBUG]   Entering main loop
    [ 2021/03/05 04:22:44 ][SecuExtender Agent][INFO]    GetOverlappedResult success, agentState.aState = 2,  agentState.aError = 0, dwReadBytes = 8
    [ 2021/03/05 04:22:46 ][SecuExtender Agent][INFO]    GetOverlappedResult success, agentState.aState = 3,  agentState.aError = 0, dwReadBytes = 8
    [ 2021/03/05 04:22:57 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:23:07 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:25:16 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:26:20 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:26:21 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:26:23 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:26:24 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:27:29 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:27:30 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:28:34 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:28:35 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:29:40 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:29:41 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:29:42 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:29:45 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:30:49 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:30:50 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:30:51 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:30:53 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:30:54 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:30:55 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:30:56 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:30:57 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:30:58 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:31:00 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:31:01 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:31:02 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:31:03 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:31:04 ][SecuExtender Agent][ERROR]   Update defaute route (0x0)
    [ 2021/03/05 04:31:10 ][SecuExtender Agent][ERROR]   network FD_CLOSE (0x0)
    [ 2021/03/05 04:31:10 ][SecuExtender Agent][ERROR]   Connection to ZyWALL is going to be shut down. (0x0)
    [ 2021/03/05 04:31:10 ][SecuExtender Agent][DEBUG]   SSL Connection is going to be closed
    [ 2021/03/05 04:31:10 ][SecuExtender Agent][INFO]    Connect to 1113640099:443
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][INFO]    Local address is 3232235785
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][DEBUG]   Connect success.
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][DETAIL]  Handshake LoopCounter: 0
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][DETAIL]  2086 bytes of handshake data received
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][DETAIL]  InitializeSecurityContext returns 0x90312
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][DETAIL]  Send 126 bytes of handshake data
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][DETAIL]  Handshake LoopCounter: 1
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][DETAIL]  274 bytes of handshake data received
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][DETAIL]  InitializeSecurityContext returns 0x0
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][DETAIL]  SSL Handshake is successful
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][DETAIL]  STREAM_SIZE: Header: 13 Trailer: 16, MaxMessage: 16384
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][INFO]    logout message has sent
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][DEBUG]   SSL Connection is going to be closed
    [ 2021/03/05 04:31:11 ][SecuExtender Agent][DETAIL]  Connection ends.
  • Zyxel_Can
    Zyxel_Can Posts: 342 image  Zyxel Employee
    25 Answers First Comment Friend Collector
    @Hi Fabio,
    Please share some information with us for better understanding;
    1- Did you try to run SecuExtender software as Administrator?
    2- Are you able to connect to SSL VPN with SecuExtender? Is the issue that you can never connect to VPN or it sometimes disconnect from SSL VPN?
    3- Does that issue always occurs?
    4- Can you please try to change Assign IP Pool subnet under Configuration > VPN > SSL VPN > Access Privilege > Edit > Assign IP Pool to another subnet.
    5- If these doesn't help you to solve the problem, can you please provide following information;
    a. C:\Users\Username\SecuExtender.log
    ‪b. ‪C:\SecuExtenderHelper.log
    c. Output of Command Prompt > route print & ipconfig /all.
    Best regards.
  • Fabio
    1- Yes but do not change
    2-yes we can connect but sometimes there is a disconnection
    3- yes it's not stable
    4- if you are talking from Firewall, other VPN are connected with no problems
    5- coming soon
  • Fabio
    attached the logs and Ipconfig
