XMG3927-50A Firmware
bananacakes
Hi there
I have recently purchased a XMG3927-50A Gateway router. However I am unable to find it on the website and only managed it coming in via an external google search.
I'm wondering where the latest firmware can be found, after an extensive (google) search I manged to find the manual but I suspect there has been a firmware update given the version numbers listed, so is there a link to firmware for this router anywhere ?
Hello @bananacakes
There is some firmware for your device from 2019 in ftp://ftp.zyxel.com/XMG3927-B50A/firmware/ as version 5.13 (ABMT.0)C0
I hope that is helpful.
Kind regards,
Tony0
Hello @bananacakes
Kind regards,
Tony0 -
tonygibbs16 said:Hello @bananacakes
Kind regards,
Tony1 -
Hello @bananacakes
You are welcome.
Any new firmware could be in that folder or under the Downloads & Resources at https://service-provider.zyxel.com/global/en/products/dsl-cpes/gfast/gfast-bridgesgateways/xmg3927-b-series
Kind regards,
Tony0 -
I cannot find firmware for this router anywhere - please advise ?0
try this address :https://www.zyxel.com/euosearch/dl-search.aspx?mci_country=uk&mci_lang=en&keyword=xmg3927&submit=Search
I have download 5.17 on 2 3927's and seems to be OK on gfast0
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
