Feature request: WIFI connection status (type)
[Deleted User]
I currently have the NWA110ax implemented at my home office. I use Nebula for the management of the device. It is possible to see the device capabilities in Nebula but not if the device is actually using WIFI 5 or WIFI 6 on a certain band. It would be very helpful if Nebula could inform me about this (both the web interface as well as the app).
I agree with Atheon. This would be a nice feature to have on the NWA110ax.0
Dear Bella,
Thank you for your reply.
Capability does not mean that the device is actually connected using WIFI 6. It only means that the device is *capable* of doing that. I would like to see the actually used standard.
In your screenshot: devices are not connected using WIFI b/g/n. Those are three supported standards by the device. The device is connected using one of them and I would like to know which one.
Regards,
Atheon0
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
