WRE6505
PSi
Hello I try to change the psw of the wlan and can not get to the adm page. http://zyxelsetup. Can anyone help me with this?
Hello @PSiHave you been able to login at all with user name admin and password 1234 through the http://zyxelsetup/ following the quick start guide at ftp://ftp.zyxel.com/WRE6505/quick_start_guide/WRE6505_001.pdf ?if not, then you could try doing a reset following section 5.3 of the User Guide at ftp://ftp.zyxel.com/WRE6505/user_guide/WRE6505_1.00.pdf and then you are supposed to get the password change screen after you then login with the admin and 1234 credentials.I hope that this is helpful.Kind regards,Tony
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
