Feature request: WIFI connection status (type)
[Deleted User]
[Deleted User] Posts: 2 image  Freshman Member
edited April 2021 in Nebula
I currently have the NWA110ax implemented at my home office. I use Nebula for the management of the device. It is possible to see the device capabilities in Nebula but not if the device is actually using WIFI 5 or WIFI 6 on a certain band. It would be very helpful if Nebula could inform me about this (both the web interface as well as the app).
  • MDL
    MDL Posts: 1 image  Freshman Member
    I agree with Atheon. This would be a nice feature to have on the NWA110ax.
  • Zyxel_Bella
    Zyxel_Bella Posts: 560 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    Hi @Atheon and  @MDL
    Thanks for the ideas!
    In the Access point > Monitor > Clients page, selet the Band and Capability to display.
    Then you can check the detailed information about clients connected to AP.
    Regards,
    Bella
  • [Deleted User]
    edited March 2021
    Dear Bella,
    Thank you for your reply.
    Capability does not mean that the device is actually connected using WIFI 6. It only means that the device is *capable* of doing that. I would like to see the actually used standard.
    In your screenshot: devices are not connected using WIFI b/g/n. Those are three supported standards by the device. The device is connected using one of them and I would like to know which one.
    Regards,
    Atheon
  • Zyxel_Bella
    Hi @Atheon,
    Thanks for the description of your expectation.
    We’ll discuss the suggestions for improvement.
    Regards,
    Bella
Nebula Tips & Tricks
