Secuextender 1.2.1 os MACOS Catalina disconnets immediately after connection
NicolaZonca
HI,
I have been working for a while with Secuextender, and all was good. Now I bought the license, and - but I am not 100% sure the timing is really coincident - it does not work anymore. It disconnects immediately after it connects. The report says:
2021-03-14 18:05:42: Viscosity Mac 1.2.1 (1296)
2021-03-14 18:05:42: Viscosity ZyXEL SSL Engine Started
2021-03-14 18:05:42: Running on Mac OS X 10.15.7
2021-03-14 18:05:42: ---------
2021-03-14 18:05:42: State changed to Connecting
2021-03-14 18:05:42: Checking reachability status of connection...
2021-03-14 18:05:42: Connection is reachable. Starting connection attempt.
2021-03-14 18:05:42: Attempting to resolve server address 109.234.62.66
2021-03-14 18:05:42: Server address resolved to IPv4 address 109.234.62.66
2021-03-14 18:05:42: Requesting authentication token from client
2021-03-14 18:05:42: No authentication token present, requesting authentication details
2021-03-14 18:05:42: Requesting authentication token from server
2021-03-14 18:05:42: Requesting token from 109.234.62.66
2021-03-14 18:05:42: Attempting to establish a connection to the remote server 109.234.62.66:8443
2021-03-14 18:05:42: Connection timed out. Remote server did not respond.
2021-03-14 18:05:42: Authentication attempt aborted
2021-03-14 18:05:42: State changed to Disconnected
Could you please help? IT quite urgent, I am remote working....
Thank you!
Thank you!
Hi @NicolaZonca,
In the logs you provided, I see that SSL VPN's port was set as 8443.
Can you please ask your company if it's still port number 8443?
If it's not, please follow to following path in the SecuExtender and edit as following, then try to connect again;
SecuExtender > Preferences... > Name of VPN Connection > Edit
Remote Server: Address: 109.243.62.66:Port_Number
(example 109.243.62.66:4443)
Best regards.
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
