IP changing back and forth between VPN Server and ISP Server
Hallo,
I have configured a easy connection to a vpn server using wan connection thru 2ltp.
Now wehn I check my IP online it keeps changing between the one the VPN Server provide me and the one from my ISP, back and forth.
Any idea where this could come from?
Can you collect the following information to check?
1) Show USG policy route
=> SSH connect to USG and type CLI.
=> Router# show policy-route
2) Show Windows routing table before L2TP connect to USG
=> In Windows command prompt: use "route print -4" command to share the dumped information to us
3) Show Windows routing table after L2TP connect to USG
=> In Windows cmd prompt, use route print -4 to dump the message again
Thank you, I hope it helps.
1)Router> show policy-routeindex: 1active: yesauto-disable: nodescription:user: anyschedule: noneinterface: nonetunnel: WIZ_L2TP_VPNsslvpn: nonesource: anydestination: anyDSCP code: anyservice: anysrcport: anynexthop type: Autonexthop: autonexthop state: Not supportauto destination: noSNAT: outgoing-interfaceDSCP marking: preserveconnectivity-check: no
2 / 3) No difference before and after:
first before, 2nd after
To be clear, I use a WAN coonection over l2tp
https://snag.gy/xry7bt.jpg
wan1_ppp ist active and connected
thanks0 -
somehow forgot to post pic for step 2 / 3 -> https://snag.gy/Fxylt3.jpg0
Hi @SemiLucas,
I see, so the USG is l2tp client, instead of l2tp server role. can you send me your configuration file via private message.
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
