XGS1210-12 - Ability to change management Vlan
MWPP
Please provide the ability to change management vlan!
We do not use VLAN 1!
This is so simple...
Thank you!
Thank you!
Hi @MWPP,
Thanks for your input.
The feature of changing management VLAN is already in our roadmap for XGS1210.
It will be implemented around Q4 of this year.
Oh Jesus, that's long. But at least something, thank you.
Are there any betas to expect any earlier? 🙈0 -
Hi @MWPP,
I will move this post to Idea section, and we will keep monitoring Likes and comments form other users in this post for evaluating reference.
More Likes and more comments might makes the feature earlier.
Whaou, are you kidding?
I just bought the switch and I fight with it to remove vlan 1 and management cant be changed
OMG!
when are you gone implement it? this is basic!
thanks0 -
Its a given that management vlan should be their if a switch does VLAN's.
Hello, really looking forward to being able to change management vlan for it is a must have. So June, here we come. Or May-be?
Just created an account here to tell how much I would value this feature too. I am looking to buy a couple of capable switches and not being able to set the management vlan is a deal breaker. Please let us know when the update is available.
While we are at it, I also notice the web management interface is accessible through http and I see no mention of https; this is also a big problem. Will this also make its way to a future software update release?
Holding my purchase until I can see at least the management vlan issue fixed. Looking forward!0 -
Hi @Pondus,
The new firmware release of XGS1210 to support management VLAN will be on schedule(the end of June) currently.
Hi @Nykau,While we are at it, I also notice the web management interface is accessible through http and I see no mention of https; this is also a big problem. Will this also make its way to a future software update release?Access WebGUI via https will also support in next new firmware together with management VLAN.
Hope it helps.0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
