XGS1210-12 - Ability to change management Vlan
MWPP
MWPP Posts: 5 image  Freshman Member
edited July 2024 in Switch Ideas
Please provide the ability to change management vlan!
We do not use VLAN 1!
This is so simple...
Thank you!
1 votes
Completed · Last Updated
Plan to release at end of June 2021
«1
  • Zyxel_Jason
    Zyxel_Jason Posts: 428 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @MWPP,
    Thanks for your input.
    The feature of changing management VLAN is already in our roadmap for XGS1210.
    It will be implemented around Q4 of this year.
    Jason
  • MWPP
    Oh Jesus, that's long. But at least something, thank you.
    Are there any betas to expect any earlier? 🙈
  • Zyxel_Jason
    Hi @MWPP,
    I will move this post to Idea section, and we will keep monitoring Likes and comments form other users in this post for evaluating reference.
    More Likes and more comments might makes the feature earlier.  :)
    Jason
  • digiseb
    digiseb Posts: 1 image  Freshman Member
    Whaou, are you kidding?
    I just bought the switch and I fight with it to remove vlan 1 and management cant be changed :(
    OMG!
    when are you gone implement it? this is basic!
    thanks
    PeterUK Posts: 4,264 image  Guru Member
    Its a given that management vlan should be their if a switch does VLAN's.
  • Zyxel_Jason
    Hi All,
    It is appreciate to hear your voice and thanks for your support.
    There is a good news about the early schedule for new firmware of XGS1210.
    The new schedule is around the end of June this year.
    Please stay tune with our New & Release.
    Jason
  • Pondus
    Pondus Posts: 1 image  Freshman Member
    Hello, really looking forward to being able to change management vlan for it is a must have. So June, here we come. Or May-be? :)
  • Nykau
    Nykau Posts: 4 image  Freshman Member
    Just created an account here to tell how much I would value this feature too. I am looking to buy a couple of capable switches and not being able to set the management vlan is a deal breaker. Please let us know when the update is available.
    While we are at it, I also notice the web management interface is accessible through http and I see no mention of https; this is also a big problem. Will this also make its way to a future software update release?
    Holding my purchase until I can see at least the management vlan issue fixed. Looking forward!
  • Zyxel_Jason
    Hi @Pondus,
    The new firmware release of XGS1210 to support management VLAN will be on schedule(the end of June) currently. :)
    Jason
  • Zyxel_Jason
    Hi @Nykau,
    Access WebGUI via https will also support in next new firmware together with management VLAN.
    Hope it helps.
    Jason
