Reboot ATP800
Hi PedrojDo you send out the daily report? Then I can be this problem:BRMario
Hello, I had it active and deactivated it according to the Ticket, but nothing, it keeps restarting.
Hi @Pedroj,
Can you please share some information with us?
1- In the second sentence you wrote “the computer restarts”. Do you mean that actually your computer also restarts, or do you imply that ATP800 restarts?
2- If your computer also restarts, can you make sure that your electricity is stable?
3- Can you please attach RS-232 to USB cable to ATP800 and the computer, collect log with a terminal software(Tera Term/putty) and share the console output with me by private message?4- Can you please also provide me diagnostic info for ATP800?
Best regards.
Hello, sorry my English is not very good.I mean ATP800, there is no computer to restart, only ATP800.The electric current is stable all connected to Online UPSIt is possible to connect by console but I have to prepare it.Will I notify you when I have it ready to connect?I pass you the diaginfo.Thanks.0
Hello, can you tell me how to pass the diaginfo?
Hello,I had a similar problem with the ATP800, it was solved by deactivating the "email security"Regards0
Hello, I don't understand what you mean ... can you tell me where this option is within the ATP800 configuration?
Hi @Pedroj,
Please collect log for ATP800 as in the following screenshots. Then, please upload the captured .log file into this forum entry.
1 –Connect to ATP800 with RS-232 console port
2- Set Speed as 115200 and click on New settings
3 – Click on File > Log… > save into a .log file
For collecting diagnostic info, please find the following path;
Maintenance > Diagnostics > Controller > Collect Now.
Then, please go to Maintenance > Diagnostics > Files > Diagnostic Files. Download the latest diagnostic file and upload into forum entry.
Best regards.
Hello ok, but I understand that I would have to leave the capture until the new reboot and then pass you the information?Thanks.0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
