SBG3300-N bricked, how to recover back.
mlml139
mlml139 Posts: 6 image  Freshman Member
edited April 2018 in Smart Home Product
my SBG3300-N bricked, 4 lan port can used as switch, Plugging an Ethernat cable from router to PC, connection light comes ON but no IP address is assigned to PC, tried assigning address to PC in the range of 192.168.1.x manually and couldn't ping the router on either .
Was wondering if there is another procedure to restore the firmware? maybe via USB or using some application that can access the router over some different protocols?
#Biz_Security_April
  • Cooldy
    Cooldy Posts: 9 image  Freshman Member
    First Comment Seventh Anniversary
    Hi mlml139,
    The procedure as below,
    Step 1
    Set PC IP:192.168.1.100/24
    Setp 2
    Set console rate: 115200
    Step 3
    Power up SBG.  Press any key to CFE mode
    Setp 4
    Go to Update Software web page via http://192.168.1.1.
    Step 5
    Click "選擇檔案" to select firmware (XXXXX.bin)
    Step 6
    Click "Upgrade Software" to upgrade SBG
  • mlml139
    Thanks will try when i back to south africa.
  • mlml139
    edited March 2021
    how is this 4 jumpers work. i tryed tx2 rx3, gnd 5,  no data come.
    this is the light like after swich on. if u pulg lan cable, the port light will on,  is this broken or still can recover back?
  • mlml139
    after i connect ttl there is nothing come out,
    did tried set IP but can not ping 192.168.1.1.
    was update fireware online, then dead.
  • mlml139
    looks like no rom in eprom, is any way to recover back?
