SecureExtender Open SSL Portail with browser Connect Now not work
Station Windows 10 with SecureExtender 4.0.20 installed. I open my URL SSL portal, select VPN_SSL after to fill in my ID/PAssword, I get the next page where I can click on "Connect now" with information latest version 4.0.20 for windows and current version is empty.
I tried to unstall SecureExtender and install it again, I used 4.0.20. I also tried to install lasted version 4.0.40.
If I use directly client SecureExtender to establish my VPN SSL connexion, it's working fine without problem. But I cannot get my connection when I use my WEB browser, by default I'm using Chrome (89.0.4389.82 (Build officiel) (64 bits)) and Opera (74.0.3911.218).
Before it's worked fine without problem, I don't know why now I cannot get the connexion with my WEB Browser. For the workaround I use directly the client "SecureExtender" but it's easier (more friendly) to use WEB browser.
Question : do you know why I cannot establish my VPN with my WEB browser as usual?
Many thanks for your help.
- When I click on it a second tab in my browser is opened : "https://localhost:996/vpn" and message appear "SecuExtender's certificate is trusted, you can try to connect tunnel again."
- Return on previously page (current version always empty) to click again on "Connect now", and again a tab is opened "https://localhost:996/vpn" with message appear "SecuExtender's certificate is trusted, you can try to connect tunnel again."
Hi @marciano,
Web SSL VPN Portal function has been deprecated due to Java security concern. So it’s not recommended to use SSL VPN Portal for establishing SSL VPN Connection.
Please kindly use SecuExtender software for stable SSL VPN connection.
Here's another discussion related to this topic;
https://community.zyxel.com/en/discussion/4824/usg-functionalities
Best regards.
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
