USG60W drops wifi - needs restart
Hi @MSc,
Can you please share some information with us;
1- How did you notice this symptom?
2- Does it always happen in the specific time?
3- Can you access using LAN interface to access to the internet?
4- Can you see SSID that broadcasted from USG60W or you can't see the SSID at all?
5- Does all of the clients have the same symtpom or just clients with the specific models?
6- What is the loading of the USG60W? Can you please check CPU, Memory and Flash usage?
7- When the issue occurs, can you please type the following command in with the console and paste the output to this topic?;
Router# show cpu average
Best regards.
I have also had issues with the wifi dropping out, but has been far less often, I think about once every 2 weeks or so.
I can see the SSID on my devices but when i attempt to connect i get nowhere and then eventually a "cannot obtain IP" from my device. My PC that is wired in connects just fine. I usually have to go into the Zyxel interface and deactivate the radio then activate it to be able to connect again. I have also checked the session monitor and I only see my 1 device hard wired in.
I am running on 4.62 on USG20W.0
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
