Jason
[NEBULA]where i found the firmware for manual update of switch NSW Total Series? Thnak You very Much
Hi @Pook ,
Please check the followings first for your NSW100-28P:
1. Your NSW100 is online on NCC.
2. Your network environment can reach the domain firmware.nebula.zyxel.com which is our firmware server.
=>You may ping firmware.nebula.zyxel.com from the Switch.
3. You gateway or ISP doesn't block HTTPS(TCP 443)
=> Nebula device uses HTTPS to download firmware.
If there is still having problem after checking above, please share your organization/site name and enable Zyxel Support at Help > Support request page, so we can access your organization to check.
Thanks.
I'm having the same issue whit NSW100-28P. IT shows in ncc but after about 5min ncc says it's offline, cannot update.
And nsw 100-28p locator indicator is black, not blue
Can you please advise what i can do?
Hi @krp,
The symptom you mentioned is "Switch can be online on NCC but gets offline after 5 minutes".
To identify the problem, please enable Zyxel Support at Help > Support request page of your organization, and share your organization/site/Switch name so that we can access your site to check.
Thanks.
Jason0 -
GUYS, is there a solution?
herer another victim stuck in V1.0
Hi @HTU1973,
Please upgrade your NSW series switch to the latest firmware. You can find the latest firmware for the NSW series switch on the End-of-Life webpage.
You may also use ZON Utility to upgrade firmware.
Hope it helps.
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 622 USG FLEX H Series
- 350 Security Ideas
- 53 Wireless Ideas
- 488 News and Release
- 108 Security Highlight
