UPGRADE Powerline Model No. PLA-407
Hierarcha
Is there a Zyxel Powerline Product which is compatible with the PLA-407 and will handle Gigabyte data transmission? I would like to upgrade some adapters, In other words, I would like to retain the use of the PLA-407 adapters in some locations and in other a Gigabyte capable adapters on the same network.
I saw a compatibility list once before, but I cannot find it now.
Hi @Hierarcha
Since PLA-407 is an old model.
You can consider to buy PLA5456 or PLA 6456.
Below are the spec of the PLA5456 and PLA6456.
https://www.zyxel.com/products_services/2000-Mbps-HomePlug-AV2-Powerline-Pass-Thru-2-Port-Gigabit-Ethernet-Adapter-PLA5456/specifications
https://www.zyxel.com/products_services/G-hn-2400-Mbps-Wave-2-Powerline-Pass-thru-Gigabit-Ethernet-Adapter-PLA6456/specifications
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
