Armor G1 only cloud???
Melak
Melak Posts: 1 image  Freshman Member
Cant you configure your router without using a cloud account? I dont want to have my router config saved on someone elses server/machine? Can you login and configure your own local router without a cloud account, and if so, how? Thanks in advance
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    edited March 2021
    Hi @Melak
    Thanks for your valuable suggestion.
    Currently, Armor G1 needs to register an account for the app using.
    After register an account, when access WEB GUI, there are two login type can choose, cloud account login and local password login.
    You can choose local password to login device.
    Best regards,
    Jerry
  • GIOMA
    GIOMA Posts: 7 image  Freshman Member
    hat is exactly the problem: I am never given the option to choose between Cloud or Local access.
    As soon as I hit the IP 192.168.123.1, the router immediately redirects to the easy123SingleSignOn page. Instead of showing a login form or a 'Local Password' button, it attempts to contact the Zyxel servers, fails, and displays the error: 'We are experiencing some service issues. Please refresh the page or try again later.'
    The UI-router is stuck in a mandatory cloud-check loop (ZAPI error 4142) that prevents the local login screen from even loading. I am effectively locked out of the device because the 'Local Password' option is hidden behind a cloud handshake that is currently failing.
