pppoe don't connect after changing config, many debug log
After changing config file, pppoe session don't connect.
Many records in console debug log
unregister_netdevice: waiting for ppp118 to become free. Usage count = 1
Hi @alexey,
Can you please share some information with us;
1- What’s the device model and firmware version?
2- Did you configure Configuration > Object > ISP Account object for pppoe connection?3- What did you change in the config file?
4- Can you try to configure another interface as PPPoE or inactivating/re-activating the ppp interface?
Best regards.0 -
hi.
1 usg 1100 fw 4.62
2 of course it was configured
3 after device reboot it cant load on current config and rollback to lastgood config. pppoe works. after manual change current config (it was wrong name for vpn tunnel) i reapply current config, after that pppoe don't connect and starts records in debug logs.
4 yes. i configure another port for this connection. without luck. only other reboot helps.0 -
1 yes. i correct only 1 ipsec name, that was shown in debug log
2 i don't think so. now device work properly on this config, and i recreate pppoe connection. config files don't have any other diffs. we use git to safe conf file from all our devices every day, so i can see diffs from any day.
3 send file0 -
Hi @alexey,
As we talked in the private message, I couldn't see the symptom by following your provided.
I renamed the object, it still connects PPPoE as expected.
How did you apply the modified configuration?
Also, may I ask the reason why you modified the config file manually?
Best regards.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
