1 Customer - 2 Physically Separate Networks - Same Location
ivessm
ivessm Posts: 45 image  Freshman Member
edited April 2021 in Nebula
Nebula question here: 1 Customer - 2 Physically Separate Networks - Same Location.
I'm wondering how Nebula handles this or am I overthinking it?
Basically we will have 2 top level routers with various switches and access points under the separate physical and logical networks. If Nebula keeps everything linier under a single account & site will it be able to keep both of these networks separate -OR- should I put them under the same Organization BUT 2 different site names for simplicity and my peace of mind?
Basically the top most question here is: Is Nebula built to handle multiple top level routers within a single site -or- is it built assuming that you will only have a single top level router at each site?
Of course, I could be overthinking this...
Thanks.
-stew
  • Zyxel_Adam
    Zyxel_Adam Posts: 429 image  Freshman Member
    Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
    Hi @ivessm ,
    Thanks for your interested in Zyxel Nebula.
    Based on your description, you have 2 separated network in the same location,as you mention "should I put them under the same Organization BUT 2 different site", we also recommend you to use 1 Organization and 2 sites to manage your network and each site place one router.
    Let me know if there is any concern.
    Adam
  • Zyxel_Adam
    Hi @ivessm ,
    Adam
Nebula Tips & Tricks
