Does anyone has the procedure how to connect a Mikrotik with 2 VLANS (dhcp service) with GS1900?
Drew74
Drew74 Posts: 1 image  Freshman Member
edited August 2022 in Switch
Hi , im trying to configure a mikrotik router with a zyxel switch. I created two Vlans and assigned a dhcp server to them but I cannot get the vlans to work on the switch, Does anyone has the procedure how to do it? especially on the mikrotik side.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,310 image  Zyxel Employee
    Hi @Drew74,
    Welcome to Zyxel community!
    I would like to make sure that have you create same VLAN on your both device?
    If yes, please remember to set VLAN port. (Go to Configuration > VLAN > VLAN > VLAN Port)
    I assume you use port 1 to connect router, so the port 1 membership should be tagged out.
    Below is the example.
    And the port should remain default.(Configuration > VLAN > VLAN > Port
    If there still have issue, please supply the scenario and topology so we can analyze the symptom.
    Zyxel Melen
