"Easy mode" "Guest Wi-Fi" cannot adjust VLANs for guest Isolation
So go with easy mode..... GUI shows LAN1: P3 p4 p5 wired and Wi-Fi. Guest network: P6 wired and "Guest Wi-Fi". Super......NOT!
Wired Guest is on separate IP range, for P6
"Guest Wi-Fi" is on same range as P3, P4, P5.
Cannot get P6 Wi-Fi to be on correct IP range
I have searched all the KBs and attempted most. Please do not respond with a link without reviewing the whole issue. i.e. how to set up VLAN, how to L2 isolation, etc
Thanks in advance. Paul
Don't use Easy mode
What are you using as a AP? is the USG60 acking as the controller?
Your VLAN setup on the switch? or and setup on the USG60?
Can you draw out the setup0 -
That is what I figured. WAC6503D-s Been working on vLans all last week. The only way I have been able to get vLan 100 or 200 to internet connect is to set them as management. Then usually have to reset AP and start over.0
Will removing the associated EZ ssids break the EZ connection. Or have to remove objects as well?0
USG60 Controller
Switch
AP
Or: USG60 controller
AP
Or: USG60
AP configured as a stand-alone
I removed the switch for stage isolating no wan connection. I have not reset the AP as stand alone.
Idea is begin simple and add complexity
Simple means no EZ, 1 VLAN, no controller.
Next add controller
Next add switch0 -
Its some what hard to remove EZ settings but you can set up around them so their not in use.
Its easier if the WAC6503D-s is connected to the USG60
The way I have done a guest network is LAN1 P4 as non-guest SSID Local bridge VLAN 1 VLAN Support off.
Make a VLAN 200 on the USG60 base port LAN1 make a zone call it Guest Wi-Fi so its not lan1 SSID Local bridge VLAN 100 VLAN Support on.
Have a routing rule from Guest Wi-Fi to WAN1 and a firewall rule
OK will start w 6503 attached to USG. Get it working then post again.
PS: It was not too hard to repl EZ. Reset, back to 1234 pw. Starting again.
I thought EZ was too EZ. WiFi/Guest wizard is useless except for home use. This is not home hardware.
Thanks will get to it. Frustrated Paul.0 -
The way I have done a guest network is:
1) P3,4,5 Lan1 (P6 is guest interface), ssid is default Zyxel vLan support off..... OKMake a VLAN 200 on the USG60 base port LAN1 make a zone call it Guest Wi-Fi so its not lan1 SSID Local
bridge VLAN 100 VLAN Support on. Zone GuestWiFi members guest and vLan200
1) vLan200, base port lan1, id 200, fixed ip 0.0.0.0, dhcp: none, Enable proxy arp ,
2)Zone User config added: GuestWifi, member: vLan200 & guest
3) SSID: GuestSSID, local bridge, vLan ID: 200 vLan support : ONHave a routing rule from Guest Wi-Fi to WAN1 and a firewall rule????
1) Policy Control??? New object: GuestPolicy from: GuestWiFi to: WAN other fields: default
2) Routing rule????Zyxel SSID only 1 broadcasting Has internet. Guestssid SSID not broadcasting.
Hi @ppandmary
Our easy mode does not support to configure VLAN setting for the SSID. If you need to use VLAN interface for the stations, you have to use expert mode.
According to your requiremen, you need two SSID. One is with VLAN100, and another is with VLAN200. Here is the SOP to create two AP profiles that I assume you only have one AP which is connected to LAN1 itnerface.
First, please ensure the AP has been managed by USG60, and connect the AP to the lan1.
1. Create VLAN100 and VLAN200 interfaces based on lan1 with static IP address and DHCP server.
2. Create 2 AP profiles. One is for VLAN100, and another is for VLAN200. Please add the security profiles if needed.
The station should get different IP address when connecting to different SSID. Not sure what you need for Guest WiFi. Please describe your requirement more detail, then I will know how to provide the suggested configurations.
Joslyn0 -
This is beta testing. All guest wifi needs so far is isolation and internet.
A) Create VLAN100 and VLAN200 interfaces based on lan1 with static IP address and DHCP server.
DONE.
DONE.
C) The station should get different IP address when connecting to different SSID.
YES different IP ranges for diff SSID. Only Zyxel SSID can ping 8.8.8.8 all others no internet.
6 picts attached showing vLan100
Once wifi is set Threshold and steering will be set for both SSIDs0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
