NSG-50 block by MAC address
Gareth
Gareth Posts: 12 image  Freshman Member
edited April 2021 in Nebula
Hi
Is there any way to create a "Blocked" profile for the NSG-50? I have an ethernet device that I want to be able to block or restrict access to the internet based on a schedule. I can easily create a schedule for an SSID but is there a way to create a schedule for devices hard wired to the NSG-50?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,637 image  Zyxel Employee
    Hi @Gareth,
    I would like to mention you that NSG could not block by MAC address.
    I suggest you to use layer 2 device(switch or ap) to block by MAC address.
    Hope it helps.
    Zyxel Melen
Nebula Tips & Tricks
