Load Balancing Products
MirkoBT
MirkoBT Posts: 1 image  Freshman Member
Hello everyone,
I'm looking for all the Zyxell Firewall products, that support the Trunk Load Balance between two ADSL connection provided by two different routers; the routers are connectable by RJ45 cables.
Any suggestion on which Firewall i should choose?
Thanks in advance for your help.
  • Zyxel_Can
    Zyxel_Can Posts: 342 image  Zyxel Employee
    25 Answers First Comment Friend Collector
    MikroBT,
    You can consider USG FLEX 200 or ATP200.
    Specs of USG FLEX series:
    https://www.zyxel.com/products_services/USG-FLEX-Firewall-USG-FLEX-100/license-and-spec
    Specs of ATP series:
    https://www.zyxel.com/products_services/ATP-Firewall-ZyWALL-ATP100/license-and-spec
    For Zyxel devices, load balancing settings can be found under Configuration > Interface > Trunk > Default WAN Trunk menu.
    A Trunk interface supports 3 types of Load Balancing Algorithms;
    1-    Weighted Round Robin is for balancing traffic load between interfaces based on their respective weights. An interface with larger weight transmits more traffic than an interface with smaller weight.
    2-    Least Load First algorithm used for sending session traffics through the least utilized trunk member.
    3-    Spillover algorithm used for sending network traffics through to first member of the trunk until there’s enough traffic the second interface needs to be used.
    May I ask what type of Trunk interface you need?
