"Easy mode" "Guest Wi-Fi" cannot adjust VLANs for guest Isolation
- One last question. When configuring for max clients on access point is the maximum client count per radio profile name? SSID? vLan, etc?. i.e. If 8 SSIDs are added; 4X guest and 4X office how many clients can attach to AP before load moves to neighbor AP? I believe for WAC6503d-s max is 64 or 128....
- The latest 6503 wizard puts in 8 SSIDs and 8 radios; all the same.
Thanks for all your help0 -
- Thanks for all your help.
Hi @ppandmary
1-a. The Max sation number in Load Balancing means how many stations can connect to this radio.
For example, the number is 20 for each. It means we will have 40 stations on this AP. 20 is for 2.4G, and 20 is for 5G.
1-b. The Maximum Association Number for WAC6503D-S is 256. We recommended Concurrent Station/MU-MIMO station for Hotspot is 125, and recommended Concurrent Station/MU-MIMO station for Enterprise is 35. You can adjust the number based on your real sceanrio.
2. The Wizard design will create 8 SSIDs and 8 radios at the same time when you finish the Wizard setting.
Joslyn0
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 483 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
