What’s a good replacement for the NAP203 and NAP303?
NWA5123-ACHD?
You can consider the 802.11ax series model with newer standard and higher capability for users to have great experience in higher density environments.
Since the capability of NWA5123-AC HD is similar to NAP203 and NAP303 but doesn’t support wireless bridge. If you have implement wireless bridge in your topology, we suggest WAX610D that also supports wireless bridge.
WAX510D is another good choice because it has dual-optimized antenna like NAP203 if you don’t need wireless bridge.
https://www.zyxel.com/promotions/wifi6-promotion-20190930-807915.shtml
We’d appreciate your sharing of the AP’s deployment environment and applications and then provide more suggestions.
Thank you
Regards,
Bella
Thank you
Regards,
Bella
Thank you Bella for answering my question, I will go with the WAX610D and see how it works out.
David0
- 588 USG FLEX H Series
- 477 News and Release
