USG60 Wishing to block an IP Range - How to?
Content Filter needs to be activated for Geo-ip to work.
On the Address click add
name = name
address type = GEOGRAPHY
region = select one
Then go to security policy > policy control add
name = name
from = WAN
To = LAN1?
Source = your above Geo-ip object
action = deny
Thank for that.I believe we subscribe to content filter?In fact to:Could it not be activated?
Anti-Spam Gateway Anti-Virus_Bitdefender Signature Content Filter IDP SecuReporter Premium
In Licensing > Registration > service tab does it say "Activated" for Content Filter 2.0?
Have you updated the Country Database in Geo IP
Hi, Yes, all 5 are actviated.The country database is up to date and set to autoupdate.It was the IP range I set in the section 'Custom IPv4 to Geography Rules' that did not seem to work.
Hi @Blobby123,
Did you try to create Address range object and assign it to a Security Policy rule?
1- Create address range object (Configuration > Object > Address/Geo IP)
2- Assign it to a Security Policy rule (Configuration > Security Policy > Policy Control)
Also, please make sure Policy Control is enabled (Configuration > Security Policy > Policy Control)
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
